Set up a connection to Asos
Asos is an online fashion and cosmetic retailer platform.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings:
Setting
Instructions
Name your connection *
API key *
Enter your Asos API key.
How to retrieve the API key
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token auth universal connector documentation.
How to retrieve the API token
  1. Sign in to your RapidAPI account.
  2. Navigate to Apps > Add new app.
  3. Enter an App name.
  4. From Authorization type, select RapidAPI.
  5. Copy the API key.
Additional references
