Set up a connection to MachShip
MachShip is an independent cloud-based freight management system that makes freight easy for e-commerce and enterprise freight managers.
After you start the connection, configure it in the Create connection panel and complete all of the required * authentication settings:
Setting
Instructions
Name your connection *
Token *
Enter your MachShip Token.
How to retrieve the token
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token auth universal connector documentation.
  1. Sign in to your MachShip account.
  2. Navigate to Settings > My API tokens.
  3. Click Create API token.
  4. Enter a Token name.
  5. Click Create token.
  6. Copy the Token.
