3DBinPacking optimization software helps you choose the right box for every shipment.
Account type * |
Select your 3DBinPacking API account type:
Username * |
Enter your 3DBinPacking account username. |
API key * |
Enter your 3DBinPacking API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your 3DBinPacking account.
Navigate to Profile > Profile settings > API access.
Click Generate.
Copy the API key.
