AxisCare software is designed specifically for home care agencies. It helps manage various aspects of home care services, facilitating better care coordination, administration, and communication.
API version * |
Enter your AxisCare account API version. |
Site number * |
Enter your AxisCare site number. For example, if your AxisCare account URL is |
API token * |
Enter your AxisCare API token. Multiple layers of protection, including AES 256 encryption, are in place to keep your API token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your AxisCare account.
Navigate to your Admin > API token > Create new token.
Click Create.
Copy the API token.
