sidebar.
This article explains how to use the postSubmit hook to ignore error messages in a flow.
Example: Customer import errors
This example syncs Shopify refunds with NetSuite.
Some imported customers have subsidiary value that should not be updated, and those records cause a specific error:
"responseData": [ { "statusCode": 422, "errors": [ { "_userId": "5d93d813fe3c7b0ef52e58e8", "resolved": false, "code": "cant_modify_sub", "message": "Failed to save record because You cannot change the subsidiary of this entity because one or more transactions exist for this entity.", "source": "netsuite", "exportDataURI": null, "traceKey": "2178928902215" } ], "ignored": false, "id": "ExampleID", "_json": {ExampleJSON}, "dataURI": "ExampledataURI" } ]
In such cases, you can use a conditional statement in a postSubmit hook to check for that specific error message and ignore it so that those errors do not generate notifications.
Add script to process error message (postSubmit script)
In the following postSubmit hook script, the highlighted conditional statement checks for the above error message and marks it as ignored:
function postSubmitNSCreateCustomerError(options) { let responseData = processPostSubmitErrors(options, ignoreCreateCustomerErrorFn) return responseData } function ignoreCreateCustomerErrorFn(options) { let toReturn = {ignored: options.ignored, betterMessage: options.message} //Check for specific error message inside "errors" if (options.source === 'netsuite' && options.code === 'cant_modify_sub' && options.message.includes('Failed to save record because You cannot change the subsidiary of')) { toReturn.ignored = true toReturn.betterMessage = '' } return toReturn } function processPostSubmitErrors(postSubmitOptions, myProcessErrorFunction) { postSubmitOptions.responseData.forEach(function(rd, i) { if (rd.statusCode !== 422) return let processedErrors = [] rd.errors.forEach(function(re) { let errsHelper = [] let parsedMessage = re.message try { parsedMessage = JSON.parse(re.message) } catch (ex) {} // Modify the following for your needs. if (typeof parsedMessage === 'object') { if (Array.isArray(parsedMessage)) { errsHelper = parsedMessage } else if (Array.isArray(parsedMessage.errors)) { errsHelper = parsedMessage.errors } else { errsHelper.push({code: re.code, message: re.message}) } } else { errsHelper.push({code: re.code, message: re.message}) } errsHelper.forEach(function(e) { let processedErrorMessage = myProcessErrorFunction({ code: e.code || re.code, message: e.message || re.message, source: re.source, ignored: re.ignored, preMapDataRecord: postSubmitOptions.preMapData[i] }) processedErrors.push({ code: e.code || re.code, message: processedErrorMessage.betterMessage || e.message || re.message, source: re.source, ignored: processedErrorMessage.ignored || re.ignored }) }) }) rd.errors = processedErrors let allErrorsIgnored = true for (let j = 0; j < processedErrors.length; j++) { if (!processedErrors[j].ignored) { allErrorsIgnored = false break; } } if (allErrorsIgnored) { rd.ignored = true rd.errors = [] if (!rd._json) rd._json = {} rd._json.ignoredErrors = processedErrors } }) return postSubmitOptions.responseData }
Here is the preview of function output when you run the script inside the script editor:
Test the code
The following animation demonstrates how to test the code:
