Set up a connection to Tekla
Tekla is a powerful software suite for building information modeling (BIM) and structural engineering, widely used in the construction industry to design, detail, and manage complex structures.
Setting
Instructions
Name your connection *
API type *
Choose your Tekla API type:
  • Trimble Connect API: Integrate, manage, and share construction and design project data seamlessly
Environment *
Select your Tekla account environment (either Prod or Stage).
Region *
Select your Tekla account region:
  • US Master: if your account URL is https://app.connect.trimble.com/tc/api/2.0
  • EU: if your account URL is https://app21.connect.trimble.com/tc/api/2.0
  • AP: if your account URL is https://app31.connect.trimble.com/tc/api/2.0
  • AP2: if your account URL is https://app32.connect.trimble.com/tc/api/2.0
  • Stage US: if your account URL is https://app.stage.connect.trimble.com/tc/api/2.0
  • Stage AP: if your account URL is https://app31.stage.connect.trimble.com/tc/api/2.0
Token *
Enter your Tekla API token.
Additional references
