MarketTime platform is designed to streamline and optimize various wholesale and retail supply chain aspects.
ID * |
Enter your MarketTime account Repgroup ID/Manufacturer ID. For example, if your account URL is |
X-API-key * |
Enter your MarketTime API key. To obtain the API key, contact the MarketTime support team. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
