Twilio SendGrid is a cloud-based email delivery service that provides tools for sending transactional and marketing emails.
Settings |
Region * |
Select your Twilio SendGrid account region (either Global or Europe). |
API key * |
Enter your Twilio SendGrid API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
his connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Token auth universal connector documentation.
Sign in to your Twilio SendGrid account.
Navigate to Settings > API key.
Click Create API key.
Enter an API key name.
Select the Access. For more information, see Authentication.
Click Create and view.
Copy your API key.
