Absorb LMS is a cloud-based learning management system (LMS) designed to help organizations manage, deliver, and track employee training and development programs.
Settings |
Region * |
Select your Absorb LMS account region:
Auth type * |
Select your Absorb LMS account authentication type (either Custom or Token). |
Username * (only for custom auth) |
Enter your Absorb LMS account username. |
Password * (only for custom auth) |
Enter your Absorb LMS account password. |
Private key * (only for custom auth) |
Enter your Absorb LMS private key. |
API key * (for both auth types) |
Enter your Absorb LMS API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the respective documentation for Token auth and Custom auth universal connectors.
