Jobber is a field service management software designed to help small and medium-sized service businesses manage scheduling, invoicing, and client communications.
X Jobber GraphQL version * |
Enter your Jobber GraphQL API version. For example, 2024-09-23. For detailed information on version, see Active GraphQL API versions. |
OAuth 2.0 client * |
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Jobber. How to retrieve the client ID and client secret To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( ) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource |
Sign in to your Jobber developer account.
Navigate to Apps and click +New
Enter an App name and Developer name.
Enter the Celigo integrator.io Callback URL.
Select the Scopes and authorize the app.
Navigate to the Manage apps page.
From the Actions, click Menu.
Copy the Client ID.
Copy the Client secret.
