Zebra Printers are specialized devices manufactured by Zebra Technologies, widely used in logistics, retail, healthcare, manufacturing, and other sectors where there is a need to generate labels or identification marks quickly and accurately.
API type * |
Choose your Zebra Printers account API type:
Environment * (only for Asset ownership service and Send file to printer API types) |
Select your Zebra Printer environment.
Token * |
Enter your Zebra Printer token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Tenant * |
Enter your Zebra Printer tenant account number. |
Region * (Only for VisibilityIQ API type) |
Select your Zebra Printer account region.
Company name * (Only for VisibilityIQ API type) |
Enter your Zebra Printer company name. |
Partner name * (Only for VisibilityIQ API type) |
Enter your Zebra Printer partner name. |
Sign in to your Zebra developer account.
Navigate to My data services > Apps > My apps.
Click Create App +.
Enter an App name.
Enter the Celigo integrator.io Callback URL.
Select APIs.
Click Add app.
Copy the Consumer key (Token).
Navigate to Tenant service API > View details > Servers.
Click Authorize.
In APIKeyAuth, enter the Consumer key and click Authorize.
Click Close.
Expand My tenant and click Try it out.
Click Execute.
From the Response body, copy the Account number.
