Leadspace is an AI-driven B2B customer data platform (CDP) designed to empower sales and marketing teams to identify, create, and accelerate pipelines with the highest probability of conversion.
Auth type * |
Select your Leadspace account authentication type (Custom or Token). |
Program ID * |
Enter your program ID provided by the Leadspace support team through email. |
Authentication secret * |
Enter your authentication secret provided by the Leadspace support team through email. Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Token * |
Enter your perpetual token provided by the Leadspace support team through email. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Custom and Token auth universal connector documentation respectively.
