OneStock is an Order Management System (OMS) that helps retailers unify inventory across all sales channels to optimize fulfillment and delivery.
This video demonstrates creating a OneStock connection.
API Version |
Select your OneStock API version (either V2 or V3). |
Environment * |
Select the required environment.
Auth type * |
Select your OneStock account authentication type (either Custom or Token). |
Site ID * |
Enter your OneStock site ID. For example, if your URL is https://admin-qualif.onestock-retail.com/c1380/order/list, then |
User ID * |
Enter your OneStock account username. |
Password * |
Enter your OneStock password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Custom and token auth universal connector documentation.
