When you configure an export, import, other type of flow step using the prebuilt Rhythm Systems connector, you can select any of the API operations listed below, organized by API type.
If your API endpoint isn’t listed here, switch the flow step to HTTP mode and configure the endpoint provided in the Rhythm Systems API documentation. You can also create a composite endpoint for this application in HTTP mode.
Resource |
API endpoint |
Export |
Import |
Goals |
Create a new goal |
X |
Update a goal |
X |
Update status by goal ID |
X |
Update one or more statuses in a single call |
X |
Tasks |
Get task |
X |
Create a new task |
X |
Update a task |
X |
