Set up a connection to Plytix
Plytix is a product information management (PIM) software that helps companies centralize, manage, and distribute product data efficiently across multiple sales channels, such as e-commerce platforms, marketplaces, and marketing tools.
This video demonstrates creating a Plytix connection.
Setting
Instructions
Name your connection *
API version
Select your Plytix account API version (v1 or v2).
API key *
Enter your Plytix account API key.
How to retrieve the API key and API password
API password *
Enter your Plytix API password.
Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
How to retrieve the API password:
Product ID * (This setting is visible only when you select v2 API version)
Enter your Plytix product ID.
How to retrieve the product ID:
  1. Sign in to your Plytix admin account.
  2. Navigate to Profile > Settings > API.
  3. Click Create API key.
  4. Enter an API key name.
  5. Select the Assigned role.
  6. Click Create API key. You will be redirected to the API keys page.
  7. Copy the API key.
  8. Copy the API password.
  2. Navigate to Products > All products > SKU.
  3. Select the required SKU and click Open in a new tab. You will be navigated to the selected product page.
  4. From the URL, copy the Product ID. For example, if the URL is https://pim.plytix.com/products/66e9a04cec2136a87a5a3aeb/attributes, then 66e9a04cec2136a87a5a3aeb is your product ID.
Additional references
