Is it Possible to Change Integration from Magento 2 Staging to Magento 2 Production
Problem: Can we change the current integration from Magento 2 Staging to Magento 2 Production?
Solution: If Magento 2 Production and Staging is a complete replica in the case of customer/order/item IDs, then you can switch. You are able to change the endpoint and then run general section flows, but there will be some issues after changing the endpoint.
1. If an order came with its the ID from production which already exported via staging, it will get ignored.
2. Additionally, this will happen with customers.
3. Item's ID will be the mismatch between both instances.
Option 1: Delete all "test" records. (We recommend this option).
Option 2: Remove values from existing records​.
These are the additional steps that need to be completed in NetSuite after changing Magento endpoints within the same connector.
1. We recommend that you delete older transactions since it is an easier task, however, if the data cannot be deleted, clear the fields for 'eTail channel', 'Magento instance' and 'Magento Website', found on the 'Etail' sub-tab and edit the 'External ID' to another value.
2. We recommend that you delete older customers since it's an easier task, however, if the data cannot be deleted, clear the fields for 'eTail channel', 'Magento instance' and 'Magento Website', found on the 'eTail' sub-tab and edit the 'External ID' to another value.
3. Edit the NetSuite items to clear the fields for 'eTail channel', 'Magento instance' and 'Magento Website', 'Magento 2 Categories', 'Magento 2 Attribute Set' all found on the 'eTail' sub-tab in NetSuite.
4. Clear the following records:
  • Celigo Magento 2 Customer Group
  • Celigo Magento 2 Customer Id Map
  • Celigo Magento 2 image id map
  • Celigo Magento 2 Item Id Map
  • Celigo Magento 2 Product Attribute Set
  • Celigo Magento 2 Product Category
  • Celigo Magento 2 Instances
  • Celigo Magento 2 Store
  • Celigo Magento 2 Store View
  • Celigo Magento 2 Websites
5. Run all 'General' flows within the connector.
