FieldAware is field service management software designed to serve your daily operations like scheduling, dispatching, and invoicing to empower field technicians by bringing project information to their fingertips.
API key * |
Enter your FieldAware API key provided by the FieldAware support team. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Custom auth universal connector documentation.
