Set up a connection to Newegg
Newegg is an online shopping portal for laptops, gaming, PC parts, PC building, and more.
Setting
Instructions
Name your connection *
Account type*
Select your Newegg account environment:
Newegg: if your Newegg account URL is https://www.newegg.com.
Newegg Business: if your Newegg account URL is https://www.neweggbusiness.com.
Sender ID *
Enter your Newegg sender ID.
dataLoad.svg​​ How to retrieve the sender ID
API key *
Enter your Newegg API key.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
API secret *
Enter your Newegg API secret.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API secret safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the API secret
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see custom auth universal connector documentation.
How to retrieve the sender ID, API key, and API secret
  1. Sign in to your Newegg developer account.
  2. Hover on username and select Data feed settings.
  3. In the API settings tab, click Request and provide your contact information.
  4. Click Register.
  5. Copy Seller ID.
  6. Copy API key.
  7. Copy API secret. For more information on APIs, see API access authorization.
Additional references
