SugarCRM is customer relationship management (CRM) software that helps businesses streamline their sales, marketing, and customer support operations. It offers a robust set of tools for managing customer interactions, improving engagement, and driving growth through data-driven insights and automation.
Version * |
Enter your SugarCRM account's endpoint version. |
Subdomain * |
Enter your SugarCRM subdomain. For example, if your URL is |
Client ID * |
Enter your SugarCRM client ID. A client ID of "sugar" automatically generates an OAuth Key in the system for password authentication, and client ID of "support_portal" generates an OAuth Key for portal authentication. The administrator can create additional client ID's in Admin > OAuth Keys to enable additional grant types. If you populate the client secret, the system will validate it against the client ID. |
Platform * |
Enter your SugarCRM platform type. The available platform types in SugarCRM include "base," "mobile," and "portal". Defaults to "base" allowing you to have custom meta-data per platform. If using a value other than "base", it should be registered using the platform extension or configure an API platform in the Administration panel. |
Username * |
Enter your SugarCRM account username. |
Password * |
Enter your SugarCRM account password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
