Maxio (formerly Chargify) is a subscription billing and financial operations platform that helps B2B SaaS companies manage recurring billing, automate invoicing and dunning, track SaaS metrics, and handle revenue recognition with accurate reporting and compliance.
Subdomain * |
Enter your Maxio subdomain. For example, if |
Environment * |
Seelct your Maxio account environment region (US or EU). |
Server * |
Select your Maxio server:
API key* |
Enter your Maxio API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Custom auth universal connector documentation.
Sign in to your Maxio account.
Navigate to Config > Integrations > API keys.
Click New API key.
Enter a Description.
Click Save.
Copy the API key.
