Parseur helps extract data from emails, automate data entry workflow, and integrate with other applications.
This video demonstrates creating a Parseur connection.
Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections you’ve created. |
API token key * |
Enter your Parseur API token key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding Custom settings, see custom universal connector documentation.
Sign in to your Parseur account.
Navigate to Account > Overview.
Copy API key.
