Set up a connection to Recurly
Recurly is the subscription management and recurring billing platform that drives transformational growth.
  • If you select the Recurly v2 API type, you can use only v2 version supported APIs.
  • It is recommended to use the Recurly v3 API type to make use of the v3 version supported APIs, because the v2 API type will be deprecated soon.
Setting
Instructions
Name your connection *
API type *
Select your Recurly account API type:
  • v2: Access legacy API endpoints to manage subscriptions, accounts, invoices, and billing workflows for existing integrations.
  • v3: Use the current API to manage subscriptions, plans, customers, invoices, payments, and billing workflows with expanded features and improved resource models for modern integrations.
v2 API type:
API version
Select one of the API versions, either 2.13 or 2.18 depending on the Recurly API version you're using.
Subdomain *
Enter your Recurly subdomain. To find your subdomain, sign in to your Recurly account. For example, if https://pgtest.recurly.com is the URL, then pgtest is your subdomain.
API key *
Enter your Recurly API key.
v3 API type:
Region *
Select your Recurly account region (US or EU).
API key *
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Basic universal connector documentation
How to retrieve the API key
  1. Sign in to your Recurly account.
  2. Navigate to Integrations > API credentials > Private API key .
  3. Copy the default Private API key.
    If required, click Add Private API key to generate a new API key.
