RetailOps platform designed to help retailers manage and streamline their operations. It provides tools for inventory management, order fulfillment, purchasing, reporting, and customer management.
API key * |
Enter your RetailOps API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API token safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Custom auth universal connector documentation.
Sign in to your RetailOps account.
Navigate to Administration > System config > Users.
Select your user account.
Click Add API key.
Copy the API key.
Make sure to save your API key securely since it will not be displayed again.
