Set up a connection to Asana
Asana is a web and mobile work management platform designed to help teams organize, track, and manage their work.
This video demonstrates creating an Asana connection.
After you start the connection , you have to configure it in the Create connection panel and must complete all of the required * authentication settings:
Setting
Instructions
Name your connection *
Personal access token *
Enter your Asana personal access token. According to Asana, these should be used similarly to OAuth access tokens when accessing the API, and you should pass them in the Authorization header, such as: curl -H "Authorization: Bearer ACCESS_TOKEN https://app.asana.com/api/1.0/users/me
Multiple layers of protection, including AES 256 encryption, are in place to keep your personal access token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
How to retrieve the personal access token
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see  token auth universal connector documentation.
  1. Sign in to your Asana account.
  2. Click your profile and select My settings.
  3. Navigate to Apps > Manage developer apps > Personal access token.
  4. Click +Create new token.
  5. Enter the Token name.
  6. Read the API terms and conditions.
  7. Check the I agree to the API terms and conditions box.
  8. Click Crete token,
  9. Copy the Token and save it in a safe place.
Additional references
