Set up a connection to Certify
Certify is an expense management software. It provides the solution to manage travel and expenses.
Setting
Instructions
Name your connection *
API key *
Enter your Certify API key.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
API secret *
Enter your Certify API secret.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API secret safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the API secret
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Custom auth universal connector documentation.
How to retrieve the API key and API secret
  1. Sign in to your Certify account.
  2. Navigate to System configuration > System integration > View and edit integrations.
  3. Click Manage Certify API key. The Certify API configuration page opens.
  4. Copy Certify API key.
  5. Click Generate new secret.
  6. Copy Certify API secret.
    • Only Certify admins can generate the API key.
    • Make sure you copy the secret; you can see it only once.
Additional references
