Mailgun is a transactional email service provider that streamlines your email efforts by providing troubleshooting, status logs, email analytics, and optimized delivery.
API version |
Select your Mailgun API version. |
Region * |
Select your Mailgun account region:
API key * |
Enter your Mailgun API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Basic auth universal connector documentation.
Sign in to your Mailgun account.
Navigate to Control panel > Profile menu > API security > API keys.
Click Add new key.
Enter a Description.
Select a Role.
Click Create key.
Copy the API key.
