Okta provides cloud software that helps manage and secure user authentication into applications, and for developers to build identity controls into applications, website web services, and devices.
Token * |
Enter your Okta token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Subdomain * |
Enter your Okta subdomain. For example, if your URL is |
Sign in to your okta.com account.
Navigate to Security > API.
Click Tokens. The Create token appears.
Copy the Token Value .
