Set up a connection to Procurify
Procurify is procurement software that provides real-time visibility and control over all business spending in one platform.
Setting
Instructions
Name your connection *
Subdomain *
Enter your Procurify account subdomain. For example, if your Procurify account URL is https://celigo.procurify.com, then celigo is the subdomain.
Client ID *
Enter your Procurify client ID.
Fetch data {//theme.zdassets.com/theme_assets/1098969/5157503509223f89f9b3e7578d2ca78ce882fc18.svg}How to retrieve the client ID
Client secret *
Enter your Procurify client secret.
Multiple layers of protection, including AES 256 encryption, are in place to keep your secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Fetch data {//theme.zdassets.com/theme_assets/1098969/5157503509223f89f9b3e7578d2ca78ce882fc18.svg}How to retrieve the client secret
  1. Sign in to your Procurify account.
  2. Navigate to Settings > Manage user.
  3. Create a User. For information on how to create a user, see API credentials.
  4. Navigate to Settings > Integration > Procurify API.
  5. Click View.
  6. Add a Description and click Create application.
  7. Copy the Client ID.
  8. Copy the Client secret.
