Set up a connection to Skubana
Skubana is an eCommerce operation platform designed to streamline multi-channel inventory management and other eCommerce processes and operations.
Setting
Instructions
Name your connection *
Environment *
Select your environment:
  • Sandbox if the account is created at https://demo.skubana.com/login
  • Productionif the account is created at https://app.skubana.com/login
Subdomain *
Enter your Skubana subdomain.
For example, if your URL is https://api.demo.skubana.com/, then api.demo is the subdomain.
Scopes *
Scopes are OAuth 2.0 permissions that Skubana defines to limit access to your account.
How to configure scopes
    1. Click Scope.
      – or –
    3. Click Save.
