Set up a connection to WooCommerce
WooCommerce is an open-source e-commerce platform plugin. It helps online merchants to sell and service products online.
This video demonstrates creating a WooCommerce connection.
Setting
Instructions
Name your connection *
Shop name *
Enter the shop name of your WooCommerce account. For example, if your WooCommerce shop URL is https://celigo.com/wp-json/wc/v1/orders, enter celigo.
Consumer key *
Enter your WooCommerce consumer key.
dataLoad.svg​​ How to retrieve the consumer key
Consumer secret *
Enter your WooCommerce consumer secret.
Multiple layers of protection, including AES 256 encryption, are in place to keep your consumer secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the consumer secret
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Basic auth universal connector documentation.
How to retrieve the consumer key and consumer secret
  1. Sign in to your WordPress account.
  2. Navigate to WooCommerce > Settings > Advanced > REST API.
  3. Click Add Key. The Key details page appears.
  4. Add a Description and select the WordPress User.
  5. Choose the level of Permissions. Access levels include Read access, Write access, or Read/Write access.
    Make sure you choose Read/Write access when you have both read and write use cases.
  6. Click Generate API key.
  7. Copy the Consumer key and Consumer secret.
    Make sure to copy your key and secret because you cannot see them once you leave this page.
