Avalara is an automation technology and cloud-based indirect tax compliance software. It helps users to integrate with the systems to save time and reduce customs delays.
After you start the connection , you have to configure it in the Create connection panel and must complete all of the required* authentication settings
Username * |
Enter your Avalara account email. |
Password * |
Enter the Avalara account password. Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Environment* |
Select one of the following, depending on the Avalara account instance you're connecting to: Production: If your AvaTax account URL is Sandbox: If your AvaTax account URL is |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic auth universal connector documentation.
Additional references
