Set up a connection to Dun & Bradstreet
Dun & Bradstreet helps companies improve their business performance through data and insights. It provides solutions to grow revenue, manage risk and compliance, drive efficiencies, and improve communities.
After you start the connection , you have to configure it in the Create connection panel and must complete all of the required * authentication settings:
Setting
Instructions
Name your connection *
Username*
Enter your Dun & Bradstreet account username.
Password*
Enter your Dun & Bradstreet account password.
Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text.
