Set up a connection to Wrike
Wrike is a widely used collaborative work management platform that helps teams streamline tasks, projects, and workflows in real-time, facilitating efficient communication, planning, and tracking of work progress across organizations.
Setting
Instructions
Name your connection *
Scopes *
Scopes are OAuth 2.0 permissions that Wrike defines to limit access to your account.
How to configure scopes
  1. Click Scope.
    1. Check the scopes you want to add and click the > button.
      – or –
      To access all of the scopes in the API, click the » button.
  2. Click Save.
Additional references
