Set up a connection to Shift4Shop (formerly 3dCart)
Shift4Shop is an eCommerce solution provider that makes it easy to build the perfect website for your business and start selling your products or services online.
Setting
Instructions
Name your connection *
Secure URL *
Enter your Shift4Shop account secure URL.
dataLoad.svg​​ How to retrieve the secure URL
Private key *
Enter your Shift4Shop private key.
Multiple layers of protection, including AES 256 encryption, are in place to keep your private key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
dataLoad.svg​​ How to retrieve the private key
Token *
Enter your Shift4Shop token.
dataLoad.svg​​ How to retrieve the token
  1. Sign in to your Shift4Shop account.
  2. Navigate to Settings > Store settings > Store information.
  3. Copy the Secure URL or in the developer account, navigate to Stores that are using this APP, and copy the Store.
How to retrieve the private key and token
  1. Sign in to your Shift4Shop developer account.
  2. Click Edit for the required application.
  3. Navigate to Dashboard > Private key, click Show key.
  4. Copy the Private key.
  5. Navigate to Stores that are using this APP and copy the Token.
