4castplus is a project cost management software tool. It helps to get deep insight and visibility into your entire portfolio of projects and programs.
After you start the connection, configure it in the Create connection panel and complete all the required * authentication settings:
Subdomain * |
Enter your 4castplus subdomain. For example, if |
Username * |
Enter your registered 4castplus account username. |
Password * |
Enter your registered 4castplus account password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this password again; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see ???Token auth universal connector documentation.
