Litmos is designed for software applications and information systems that decrease time-to-value and increase user adoption, making content more accessible and easier to find.
After you start the connection, you have to configure it in the Create connection panel and must complete all of the required * authentication settings:
API key * |
Enter your Litmos API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
The Litmos API is not enabled for trial accounts.
Access to requests on the API is restricted by access level (Learner, Team Leader, Administrator, or Account Owner).
Use the steps provided by Litmos to retrieve your API key if you are an account owner.
