Vroozi is a procure-to-pay platform which helps digitally connect people and data. Business transactions are simplified in how users buy and pay for products and services with zero friction.
Enter a clear and distinguishable unique name for your connection so that it will be helpful later when selecting among the list of connections that you’ve created. |
Access token* |
Enter your Vroozi Access token. The authentication token is provided to you by the service provider. In some cases, a service may have a token request process or tokens that expire after a given time. Use the refresh fields to instruct integrator.io on how to request and extract the token from the response. |
Account type* |
Select one of the following, depending on the Vroozi account instance you're connecting to: Production: live production environment. Select Production if your API Endpoint starts with https://api.vroozi.com. Sandbox: user acceptance testing environment. Select Sandbox if your API Endpoint starts with https://sandbox-api.vroozi.com. |
API key* |
Please enter your API Key here.API Key is generated after creating your application. To retrieve your API key, multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s app key safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. |
Log in to your Vroozi account.
Navigate to APIintegration >Credentials.
Click Add new application to generate a Vroozi application and copy its connection information.
Name the new application and click Save.
Vroozi displays the Access token.
Copy the app’s API key for use in the connection.
Refreshing the Vroozi Access token will generate a new token.
