Slack is a messaging app for the workplace. It helps you to work in a more connected, flexible, and inclusive way.
API type * |
Choose your Slack API type:
API version * |
Enter your Slack account API version (v1 or v2). |
Auth type * |
Select your Slack account authentication type (either OAuth 2.0 or Token). |
Token * (also API token for the SCIM API type) |
Enter your Slack token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
User scopes * |
Scopes are OAuth 2.0 permissions that Slack defines to limit access to your account. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see OAuth 2.0 auth and token universal connector documentation respectively.
Sign in to your Slack account.
Click Your Apps and select an application.
Navigate to the OAuth and Permissions tab.
Click Allow to view the token.
Copy the token.
Click Save and authorize to commit your changes and proceed to sign in with Slack
After signing in, review the permissions for the integration and click Accept.
