Loop Returns is a returns platform that helps to improve retention by encouraging your customers to exchange rather than request a refund.
Loop Returns documentation: API guide, Authentication
Additional reference: Supported Loop Returns APIs
Contents
- A. Set up a Loop Returns connection
- B. Provide required Loop Returns application details
- C. Edit advanced Loop Returns settings
- D. Test the connection
A.Set up a Loop Returns connection
Start establishing a connection to Loop Returns in either of the following ways:
In the resulting Application list, click Loop Returns.
The Create connection panel opens with required and advanced settings.
At this point, you’re presented with options for providing Loop Returns authentication.
API version (required): Select the API version, either v1 or v2 depending on the Loop Returns API version you're using. Based on the selected API version, you will be able to use the respective API operations.
API key (required): Enter the API key from your Loop Returns account. Multiple layers of protection are in place, including AES 256 encryption, to keep your token safe.
- Sign in to your Loop Returns developer account.
- Navigate to Settings > Developers > API keys.
- Copy the existing API key or click Generate API key for new API key.
Before continuing, you have the opportunity to provide additional configuration information, if needed, for the Loop Returns connection.
Once you have configured the Recurly connection, you have a few options for continuing:
- Save & close – click to test and save the connection and exit the Create connection panel
- Close – click to exit without saving any new changes
