CartRover is an e-commerce integrations technology company. It helps to connect your order sources, destinations, and 3PL partners today.
This video demonstrates creating a CartRover connection.
After you start the connection , you have to configure it in the Create connection panel and must complete all of the required * authentication settings:
API user * |
Enter your CartRover API user. |
API key * |
Enter your CartRover API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. The method of generating API keys differs, depending on whether you are accessing the CartRover Cart, Merchant, or Warehouse API. For more information on how to retrieve the CartRover API Keys, see CartRover instructions for each API, |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see basic auth universal connector documentation.
Sign in to your CartRover integration manager account.
Navigate to Merchants > API keys.
Click New setup. The New API setup page appears.
Enter Name.
Copy API user.
Copy API key.
Click Ok to save and test the connection with the same credentials.
