LogiSense is a cloud-based subscription billing platform that helps you grow your business.
Store URL * |
Enter your LogiSense account URL. For example, if your LogiSense account URL is |
Version * |
Enter your LogiSense account API version. |
Username * |
Enter your LogiSense account username. |
Password * |
Enter your LogiSense account password. Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Client ID * |
Enter the LogiSense client ID provided by the LogiSense professional services team. Multiple layers of protection, including AES 256 encryption, are in place to keep your client ID When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Reach out to the LogiSense professional services team to whitelist the integrator.io IP addresses.
