Orderful is a complete cloud EDI platform for manufacturers, distributors, retailers, and technology companies.
This video demonstrates creating an Orderful connection.
Provide a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting a list of connections you’ve created. |
Token * |
Enter your Orderful API token. Multiple layers of protection, including AES 256 encryption, are in place to keep your API token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token-based auth universal connector documentation.
Sign in to your Orderful account.
At the upper right, click your avatar and select Settings.
Navigate to Organisation settings> API credentials.
Click Show. The API token message appears.
Read the message and click I Understand to view the API token.
Copy the API token.
