Inspectorio is a cloud-based SaaS platform that helps brands, retailers, manufacturers, and suppliers to manage their risks by providing actionable insights.
This video demonstrates creating an Inspectorio connection.
After you start the connection, configure it in the Create connection panel and complete all the required * authentication settings:
Environment * |
Select your Inspectorio account environment: Pre-Production: if your Inspectorio account URL is
Production: if your Inspectorio account URL is |
API key * |
Enter your Inspectorio API key. Multiple layers of protection, including AES 256 encryption, are in place to keep your API key safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see custom auth universal connector documentation.
Sign in to your Inspectorio account.
Navigate to Configuration > API keys.
Click + Create API key.
Copy API key.
