Set up a connection to Acumatica
Acumatica is a complete cloud ERP platform that provides solutions for all your business management needs.
Setting Instructions
Name your connection *
API type *
Choose your Acumatica account API type:
  • Default: Get REST API provided by Acumatica, to interact with core system functionalities
  • Ecommerce: Get integration with e-commerce platforms connecting an online storefront and Acumatica's financials, inventory, product data, and fulfillment processes.
  • Manufacturing: Get integration, extend, and automate processes related to manufacturing operations.
Mode *  Select your Acumatica account mode (either Cloud or On-premise). For more information, see Learn about an on-premise agent.
Agent * (for On-premise mode only)
Select an agent from the list.
To connect to an on-premise application, integrator.io requires that an agent be installed on a networked computer.
API version (for Default and Ecommerce API type only) Select your Acumatica account API version.
Auth type *  Select your Acumatica account authentication type. The OAuth 2.0 authentication type is highly recommended rather than Cookie.
OAuth 2.0 auth type
Instance URI *  Enter the instance URI shown in your Acumatica account URL. For example, https://try.acumatica.co.
Endpoint name *  Enter the endpoint name found in your Acumatica account under Web service endpoints. Currently, we are supporting the Default, Manufacturing, and Ecommerce as endpoint names.
OAuth 2.0 client *
Select the OAuth 2.0 client that stores the client ID and client secret provided to you by Acumatica.
To add an OAuth 2.0 client and configure your credentials, click the plus (+) button. Click the edit ( edit.svg) button to modify a selected OAuth 2.0 client. For more information, see Create an OAuth 2.0 iClient resource.
Scopes
Scopes are OAuth 2.0 permissions that Acumatica defines to limit access to your account.
How to configure scopes
Cookie auth type:
Username *  Enter your Acumatica account username.
Password *
Enter your Acumatica account password.
Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Company  Enter your Acumatica account name as the company.
  1. Sign in to your Acumatica account.
  2. Navigate to Integrations > Connected applications.
  3. Give a suitable Client name.
  4. Select the OAuth 2.0 flow.
  5. Click Save.
  6. Copy the Client ID.
  7. Click Add shared secret.
  8. Enter a Description.
  9. Copy the Value (client secret).
  1. Click Scope.
    – or –
  3. Click Save.
Caution
Do not add the scope api:concurrent_access. It is unrelated to integrator.io connection concurrency, and it will cause the connection to fail since the expected cookie is not sent along with the token.
Save and authorize
  1. Click Save and authorize to commit your changes and proceed to sign in with Acumatica
  2. After signing in, review the permissions for the integration and click Accept.
