G2 is a software marketplace that helps to compare the best business software and services based on user ratings and social data.
This video demonstrates creating a G2 connection.
After you start the connection , configure it in the Create connection panel and complete all the required * authentication settings:
API token * |
Enter your G2 API token. Multiple layers of protection, including AES 256 encryption, are in place to keep your API token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your G2 account.
Navigate to Integrations > API tokens and apps.
In API tokens, enter the Label name.
From Integration partner, select the required application.
Click + Create new token.
Copy API token.
