lexbizz is a data platform that helps for expansive data access, powerful analytics, and automation in real-time.
Auth type * |
Select Cookie as the authentication type for this connection (the OAuth 2.0 option is described separately). |
Instance URL* |
Enter your lexbizz account instance URI. For example, if your base URI is |
Endpoint name * |
Enter your lexbizz endpoint name. |
Endpoint version * |
Enter your lexbizz endpoint version. |
Username * |
Enter your lexbizz account username. |
Company * |
Enter your lexbizz account company name. |
Locale * |
Enter your lexbizz account locale. |
Password * |
Enter your lexbizz account password. Multiple layers of protection, including AES 256 encryption, are in place to keep your password safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Cookie universal connector documentation.
Sign in to your lexbizz account
Navigate to More items > Integration > Preference > Web service endpoints.
Copy the Endpoint name.
Copy the Endpoint version.
