Anaplan is a cloud-native enterprise planning platform that helps businesses connect data, people, and plans across all departments for faster and smarter decision-making.
Enter a clear and distinguishable name. (Throughout integrator.io imports and exports, you will have the option to choose this new connection.) A unique identifier will prove helpful later when selecting it from a list of the connections that you’ve created. |
API type * |
Choose your Anaplan API type:
Auth type * (Only for SCIM API type) |
Select your Anaplan authentication type (Token or Basic). |
Username * |
Enter your Anaplan account username. |
Password * |
Enter your Anaplan account password. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. |
Environment * (Only for Financial Consolidation API type) |
Select your Anaplan account environment:
Token * (Only for Financial Consolidation API type) |
Enter your Anaplan token. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. How to retrieve the token |
Tenant * (Only for Financial Consolidation API type) |
Enter your Anaplan tenant ID. For more information, see Authentication. |
Use an FTP connector to upload files to Anaplan. If you are sending BLOB files from NetSuite to Anaplan, you can customize your flows based on the NetSuite to FTP template.
Sign in to your Anaplan Financial Consolidation account.
Navigate to Security module > User API token.
Click New API token.
Enter a Description and set an Expiration date.
Click Save.
Copy the Token.
