Easyship is a cloud-based shipping management tool that helps you to sync your orders, generate pre-filled labels, and get automatically updated tracking numbers in your store.
After you start the connection, configure it in the Create connection panel and complete all the required * authentication settings:
API type * |
Choose your Easyship API type:
API type: Legacy |
Access token * |
Enter your Easyship access token. Multiple layers of protection, including AES 256 encryption, are in place to keep your access token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
API type: 2024-09 |
API token * |
Enter your Easyship access token. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text. |
Sign in to your Easyship account.
Navigate to Connect > + New Integrations.
Click API integration.
From Integration type, select Celigo.
Enter Integration name.
Click Connect. The Integration page appears.
Copy the Access token.
From Integration type, select I'm developing a custom integration.
Select API version.
