Faire is an online marketplace for retailers and brands.
After you start the connection , configure it in the Create connection panel and complete all the required * authentication settings:
| Setting | Instructions |
| Name your connection * | Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections in your account. |
| Account type * |
Select your Faire account environment:
| API access token * |
Enter the API token provided for Faire marketplace seller integration. (Submit a Faire support ticket to receive your unique, secret API token.) Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API access token safe. When editing this form later, you must enter this password again; it is stored only when the connection is saved and never displayed as text. |
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see the Custom auth universal connector documentation.
