Gainsight CS is a cloud-based customer success (CS) platform that helps businesses manage customer health, drive product adoption, reduce churn, and grow customer relationships throughout the customer lifecycle.
The Gainsight CS connector is in BETA and may be subject to changes.
| Setting | Instructions |
| Name your connection * |
Subdomain * |
Enter your Gainsight CS account subdomain. For example, if your URL is https://celigo1.gainsightcloud.com, then celigo1.gainsightcloud.com is your subdomain. |
API key * |
Enter your Gainsight CS API key. For detailed information on retrieving the API key, see Generate REST API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
